Baker B150pd 18k pound forklift Lifting Issues.
I have a Baker 18k forklift. It has stopped lifting. The cylinders work and I have no leaks. Without weight I on the forks the masts raises and lowers fine and I have plenty of lift capacity with the tilt. But with weight on the forks it will not raise, but the tilt cylinders still work. HELP!!
  • Posted 13 Apr 2012 00:33
  • By burnies
  • joined 13 Apr'12 - 6 messages
Chris
Showing items 1 - 17 of 17 results.
Thanks for the info MEngr- I appreciate your time
  • Posted 19 Apr 2012 11:52
  • By bbforks
burnies;
I'll look into my archives to ID the valve that you have.
  • Posted 18 Apr 2012 08:24
  • By MEngr
  • Missouri, United States
bbforks;
This truck has a single stage limited free lift ram style lift cylinder with a pair of tilt cylinders mounted to gain added mechnical and hydraulic leverage advantage. The control valve for this particular truck is a three spool and the third spool is capped. The lift and tilt functions are controlled by the remaining spools.
  • Posted 18 Apr 2012 08:18
  • By MEngr
You really should perform pressure checks. Typically when a control valve has an issue it will lift a load but it will drift down due to wear on the body and the spool.
  • Posted 18 Apr 2012 00:06
  • By duodeluxe
  • United States
duodeluxe
Can you tell me what the part number is for the valve body? I probably need to get it rebuilt and adjusted. thanks
  • Posted 18 Apr 2012 00:01
  • By burnies
MEngr- thanks for the info- as you can probably tell I haven't worked on one of these ;o. Another question- does the lift control circuit power just the lift, or does it also power tilt, S/S. etc?
  • Posted 17 Apr 2012 23:13
  • Modified 17 Apr 2012 23:14 by poster
  • By bbforks
bbforks;
The Baker B150PD 15,000 lb lift has a power steering, lift control and drive control pumps. The truck lift pump's pick up circuit needs to be looked at along with the relief valve, and the pump's hydraulic efficiency.
  • Posted 17 Apr 2012 13:35
  • By MEngr
MEngr- does this truck have just 1 hydraulic pump that powers all functions (including P/S) or are there multiple pumps. I'm thinking maybe the hydraulic control valve is bleeding by on the hoist function- just a thought
  • Posted 17 Apr 2012 10:31
  • By bbforks
duodeluxe;
The ram style cylinder has no piston seal to disintegrate.
  • Posted 13 Apr 2012 23:14
  • By MEngr
First of all the truck has a base capacity of 15,000#, not 18,000#.
If you can tilt a load but not lift it, I would assume that all of the hydraulic functions are working properly. It sounds to me like the lift cylinder packing has disintegrated and the hydraulic fluid is dumping back to the tank.
  • Posted 13 Apr 2012 21:27
  • By duodeluxe
  • United States
duodeluxe
sounds like lots of options left to check. is there anyway my mechanic can call you directly to get some more specific information like where the suction filters are etc? Also if the pump lost its prime would I still get pressure to the cylinders and steering? Lots of questions and you sound like the person to help solve this problem for me.
thank you in advance.
chris 469-628-3344
  • Posted 13 Apr 2012 11:55
  • By burnies
burnies;
This truck has the hydraulic control lever automatically increases the engine speed with the demand for faster lift speed. Does its engine sound like it is in labor? When the valve body was inspected did the relief valve appear ok? Does the oil appear foamy? How does the velocity control valve in the lift cylinder base appear? Were the suction filters changed? Could the pump have lost its prime? Could the lift's pump have too much internal leakage? The lift cylinder is a ram type which eliminates it as a fault of internal leakage. The oil, is it of proper viscosity?
  • Posted 13 Apr 2012 11:31
  • By MEngr
Yes to my knowledge it was changed about 2 moths ago, filter and all. Pulled the valve body off today and everything looks good in the body so I am just confused. I do not believe my pump would just suddenly stop producing the pressure needed to raise the forks with weight on them. The pump does not appear to be laboring either..
  • Posted 13 Apr 2012 09:10
  • By burnies
burnies;
Your truck is contract 1934 built July 85. Has the oil been changed recently? The original oil used was Texico Rando 68. This oils normally use in ambient temperatures of 23 to 104 degrees F, and the viscosity was ISO VG 68. Is this what is in the truck?
  • Posted 13 Apr 2012 08:03
  • By MEngr
The steering is controled by the same Aux pump as the cylinders and I have no issues with that, so I am thinking I may have a Valving block issue? Can you get me a schematic for the Hyd System or at least the valves?
Thanks
  • Posted 13 Apr 2012 03:44
  • By burnies
1986 Baker B-150-PD
320-01100-0470
  • Posted 13 Apr 2012 03:41
  • By burnies
Chris
Hi bunies;
We need your serial number in order to identify the contract number for this older Linde.
  • Posted 13 Apr 2012 02:49
  • By MEngr
Aichi SR10C1SM
UN Forklift FBR25NQC3
Muncie, IN, United States
Aichi SR10C1SM
Deborah Baker Deborah Baker
