Hyster H70FT
H70FT s/n L177B09220D has intermittant battery drain, sometimes it will be good for days and then it drains the battery overnight. Have tried 2 different new batteries. When testing for battery drain with test light between ground post and cable end the light will stay on dimmly forever and the next time only for 30 seconds to a minute. No codes or other problems noticed. Any ideas?
Thanks, Darren
  • Posted 10 Apr 2012 23:12
  • By darren
  • joined 29 Apr'09 - 14 messages
  • Manitoba, Canada
The VSM on this truck has a timer circuit that can stay on as little as 30 seconds and as long as 1 hour. It sounds like you have a diode issue in the alternator. You can check it like checking the battery with no meters, just remove the wires when you shut the truck down and see if the battery goes dead. You might have an issue with the power distribution module, or the wiring harness where it goes under the battery.
  • Posted 11 Apr 2012 11:21
  • By meliftman
  • joined 31 Jan'12 - 209 messages
  • Alabama, United States
Liftman
Retired
Elberta, Al.
please add me on skype: hyster.brasil
  • Posted 11 Apr 2012 09:56
  • By hysterbrazil
  • joined 10 Oct'11 - 101 messages
  • rio de janeiro, Brazil
SMV (Konecranes) 16-1200C
UN Forklift FD50T-NJB3
