speed reduction for IC trucks
Is there an good reduction kit available for engines without electronic fuel injection. Most of the ones i have seen use a motor on the accelarator cable and a sensor on the crown wheel. The drivers get around this by pumping the accelarator pedal. The time it takes for the motor to release the cable the truck is already past its speed limit.
  • Posted 5 Apr 2012 19:48
  • By Leon_W
  • Tyne & Wear, United Kingdom
how old is the truck???most newer machines have speed reduction built in it just needs setting up
  • Posted 8 Apr 2012 21:53
  • By lifter01
  • joined 4 Jul'09 - 462 messages
Yes works on LPG and gasoline and diesel engines as well,can google search them and their web page will show at the top of the search
  • Posted 6 Apr 2012 01:24
  • By kevin_t
If you do not mind buying from across the pond Safety Systems & Controls out of Houston Texas has units that will work for your application.
Their website is wwwdotloadingzonesafetydotcom
  • Posted 5 Apr 2012 21:37
  • By scot_s
  • joined 10 Jun'04 - 63 messages
  • Michigan, United States
does this work on LPG aswel?
  • Posted 5 Apr 2012 20:23
  • By Leon_W
could check out S.L.O.W Corp. if they are still in business they are in Manitowoc WI...USA phone 920-683-9503 FAX 920-683-9511.
Worked for a company that had these installed on some trucks,it limits the amount of fuel coming into the engine when it gets up to the speed you set in it.
  • Posted 5 Apr 2012 20:09
  • By kevin_t
Morooka MFD20
Toyota 8FD45
GemOne
