Yale Transmission Fluid specs
Hello all. Can someone tell me what are the transmission fluid requirements on a Yale
Model: GP30THJUAE2545
SERIAL: A871R3199W
Thanks,
OB1
  • Posted 21 Mar 2012 04:50
  • By ob1kenobi
  • joined 22 Nov'10 - 153 messages
  • SAN P.SULA, Honduras
Cheers!
some of the older units such as the one you listed used to use the old ford DM grade (red) fluid, but since then Dextron III has replaced that and is compatible with most transmissions that use Dextron fluid now.
  • Posted 31 Mar 2012 20:32
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Email: jplayer@liftone.net
thanks garland_m!
  • Posted 31 Mar 2012 03:35
  • By ob1kenobi
Cheers!
OB1,
I do not have a manual on the lift but due to the age, if the current fluid is red you can be sure it is Dexron III. Yale switched all lifts to tractor oil after 2000.
  • Posted 31 Mar 2012 00:02
  • By garland_m
  • joined 16 Oct'09 - 212 messages
  • Virginia, United States
Work Hard and Fish Long
Need to confirm, cause I just don't want to assume it's Dexron III.
  • Posted 21 Mar 2012 13:25
  • By ob1kenobi
Libiao Robotics
Libiao Robotics
TCM FD115-3
Crown WP302020
Libiao Robotics
