ERROR CODE C0, E0,A9
Can anyone help me how to troubleshoot an error code
"C0,E0,A9" from our Toyota Electric forklift model 5FB15?
  • Posted 12 Mar 2012 12:59
  • By kenny
  • joined 12 Mar'12 - 1 message
  • taiwan, Taiwan
Showing items 1 - 15 of 15 results.
I'm just going to hijack this thread if you don't mind...
I've also got a 5FB15 in the workshop that was throwing error C0.
We replaced the CPU board, started getting C0, E0, A9.
Also tried replacing the DC-CD board, SDD board and even the main transistors.
Nothing changed.
Also cleaned contactor tips, still nothing.
Power diodes seem fine, as do the capacitors and resistors. Tried connecting a new battery, no effect.
Even ordered another CPU board replacement thinking the first came faulty.
Funny thing is when I was measuring the CN109 on the SDD board, I shorted two pins (oops!) and then the error was gone - for a few minutes. The forklift operated normally in that time.
At this point I'm completely out of ideas.
  • Posted 15 Sep 2017 21:52
  • By jure_t
  • joined 28 Feb'17 - 11 messages
  • none, Slovenia
Update: refurbished existing board, did find a blown transistor on it. After receiving refurbished board, I replaced all 3 TMP's, installed refurbished card. Unit worked great for a couple of hours then while working the sideshifter it did it again, code E0 reappeared no lift functions. Can't find any shorts, pump motor is clean, no shorts to frame at all. Could it be that the existing board is faulty & should just be replaced with new one instead of just repairing it? Any help is greatly appreciated!
Rodco
  • Posted 8 Jan 2016 16:25
  • By Rodco
  • joined 13 Nov'15 - 5 messages
Morning, we had another fork turn up on a tow truck, someone had reversed polaritized the forklift. Blew a tmp... still not working properly. Found a burnt transistor burnt in pcb. Put another board in it, seems ok. will test more today.
  • Posted 16 Dec 2015 07:50
  • By Bullfrog
  • joined 23 Oct'15 - 13 messages
  • South Australia, Australia
I had this recently and went through the same steps as you with the same results the hydraulic control board needed to be replaced as well.
Motors tested good, no chassis shorts, good batt. went through a good set of tm's to find the board bad. mine ran for 30 mins
  • Posted 15 Dec 2015 21:22
  • By stam
Hi, inspected panel, didn't see anything out of the ordinary. Did find a faulty tmp transistor. Replaced all 3 transistors, truck worked for a couple of hours & then quit again code E0 is back on. Any suggestions?
RODCO LIFT
  • Posted 15 Dec 2015 02:31
  • By Rodco
Remove the complete panel and inspect the pcb boards check the hydraulic board and connections.
also test the transistors
  • Posted 13 Nov 2015 08:14
  • By richard_m
  • joined 11 Apr'13 - 112 messages
  • lancashire, United Kingdom
hi, can you tell me what caused the code E0 & what it took to fix error. mine if a 5FBC25 WITH ERROR CODE E0:
NO HYDRAULIC FUNCTIONS. ALL CONTACTORS, FUSES & MOTORS ARE OK. OPERATOR STATED THAT LIFT WAS WORKING FINE THEN HE HEARD CONTACTORS TRIPPING BEFORE IT QUIT WORKING.
  • Posted 13 Nov 2015 03:02
  • By Rodco
RODCO LIFT
What tests did you do Richard? Cheers
  • Posted 23 Oct 2015 07:47
  • By Bullfrog
mine turned out to be the pcb board
  • Posted 14 Mar 2015 07:30
  • By richard_m
Any luck on the issue you had in November? I have A C0 code. Found the transistors bad. Changed them and they blew again shortly after. Cannot find any shorts.
  • Posted 13 Mar 2015 06:26
  • By PESLLC
  • joined 10 Oct'13 - 35 messages
  • fl, -
Hi did you find the problem?
  • Posted 11 Nov 2014 09:28
  • By richard_m
Hi did you find the problem as I've got same errors
  • Posted 9 Aug 2014 03:29
  • By richard_m
Hello alif,
Do you have the service manual of 5FB20? I have error code of E0 and A9 too. If you do please send to info at infinitetrade dot com. Thank you.
Infi
  • Posted 5 Dec 2013 08:25
  • By infinite_a
  • joined 8 Feb'13 - 14 messages
  • Tokyo, Japan
hello kenyy, do you need trouble shooting for for this truck? i have
  • Posted 20 May 2012 13:11
  • By alif
  • joined 28 Apr'12 - 83 messages
  • east java, Indonesia
I would start by checking the fuses and contactor tips.
  • Posted 13 Mar 2012 10:39
  • By rogeriwt
ROYPOW
Crown RD572513TT6860R
SMV (Konecranes) 4545CCX5
ROYPOW
