V40D Schematic
Hello Sirs & Madams...
I am in need of a wiring schematic for V40D 3EC551, Pugeot Engine,
Thanks all!
  • Posted 10 Mar 2012 03:20
  • By TheBirdman
  • joined 20 May'11 - 47 messages
  • Oklahoma, United States
Kevin,
I do not have any manuals on these old Cats. I just repaired a V50B with a Century LP regulator. I was able to get an overhaul kit for the regulator Century number 286-1554. As far as the wiring is concerned this particular truck powered the LP lock-off straight from the Key. The start assist was wired to a push button on the dash. Hope this helps
  • Posted 15 Mar 2012 15:03
  • By LTRM
  • joined 26 Jan'12 - 161 messages
  • Illinois, United States
LTRM:
Dont happen to have one for a CAT/Towmotor V40B
S/N 76M366
Need to know where the feed to the century G85 vaporizor primer coil comes from,have any other info on this truck to share??
I believe it has a flat head continental engine in it.
  • Posted 15 Mar 2012 09:32
  • Modified 15 Mar 2012 09:33 by poster
  • By kevin_t
I sent u an email Sir!
Thanks
  • Posted 14 Mar 2012 23:01
  • Modified 14 Mar 2012 23:55 by poster
  • By TheBirdman
I have the Schematic need email
  • Posted 14 Mar 2012 10:58
  • By LTRM
I don't have a schematic of this truck in electronic format, but it is rather a simple bit of circuitry.
What is the problem you are having?
Without any further information, I am going to guess you have a battery that dies intermittently, and yet you are sure the battery, cables and alt are all good and test good on the bench.
Your problem is in the plug connector at the alt, and is a broken wire internal to the insulation, replace the plug and about 3 inches of the wires.
  • Posted 10 Mar 2012 23:22
  • Modified 10 Mar 2012 23:30 by poster
Any CAT helpers out there willing to help a Bro out?
  • Posted 10 Mar 2012 04:05
  • By TheBirdman
Deborah Baker Deborah Baker
Zhejiang UN Forklift Co., Ltd
