Changed Fluids, Now Crank No-Start....
I bought a Hyster YC-40 off craigslist for $800.00. It was starting and running just fine. I changed the Hydro Oil, Engine Oil, and Transmission Fluid. Now, it will crank but not turn over. This is extremely puzzeling? Any ideas?
Thanks in advance for your help!
  • Posted 6 Mar 2012 10:31
  • By UglyShinglesLLC
  • joined 6 Mar'12 - 2 messages
  • Michigan, United States
i would check the battery and load test it to see if its ok,then check the starter,sounds like it is dragging or needs rebuilt/replaced. Do a voltage drop test from the battery to the solenoid and a drop test on the negative cables,check for good ground connection on negative cable from battery.
  • Posted 6 Mar 2012 10:46
  • By kevin_t
Yes it cranks and trys to turn over. If I hold down the gas pedal it almost makes it.
  • Posted 6 Mar 2012 10:43
"it will crank but not turn over"?? Does it just make a click or does the starter turn the flywheel and just wont fire?
  • Posted 6 Mar 2012 10:38
  • By kevin_t
Taylor TX330S
USD159,500
UN Forklift FBR25NQC3
Kai von Berg Kai von Berg
Taylor TX330S
USD159,500
