Toyota 7FGCU70 Hard starting
I have seen many of these Vortec engines. Most of them will not start until you release the key from cranking. Is this normal? The current truck I am working on is very hard to start and will only fire one out of ten times. Once it is running it is good and strong with no codes. I have excellent spark while cranking, the fuel lockoff is energized. Does anyone have any technical information on this tier II Impco?
ltrm812 at gmail dot com
Thanks
  • Posted 22 Feb 2012 23:34
  • By LTRM
  • joined 26 Jan'12 - 161 messages
  • Illinois, United States
Ignition module should be replaced at distributor , should be able to pick up one at loacal parts store or take it to parts store and have it tested numerous cycles for failure and a lot less expensive.
  • Posted 4 Mar 2012 11:49
  • By Huckleberry
  • joined 20 Jul'11 - 29 messages
  • Tennessee, United States
I have found Toyota wiring harnesses to be terrible. I'd try the following: jumper wire power directly from the battery to the ECU & jumper a ground right from the battery to the ECU & see how it starts. If this makes a difference then you have a wiring problem. If it doesn't, try advancing the timing while cranking. If advancing the timing makes starting easier, then it's an electronic part beginning to fail. I have found that advancing the timing usually will let the engine start, but then it runs terrible because the timing is to far advanced. Once the timing is put back to spec, the engine starts hard or not at all. I have found this a few times. Replacing the distributor fixes the problem- good luck.
  • Posted 3 Mar 2012 08:24
  • By bbforks
Frame grounds are as solid as can be. I know I am losing power or ground to my ECU during cranking. I just need a schematic and I can fix this truck. Spark good, LP lockoff energized, there are 8 wires going to the throttle and it is impossible to backprobe at the throttle. There is another 6 wire connector at the LP regulator that I am unfamiliar with its purpose. Schematic please!
Thanks
  • Posted 3 Mar 2012 00:41
  • By LTRM
Just to make sure. I remove the ground cable and grind/file the paint/frame and cable to bare metal. Then connect the cable. Not trying to beat a dead horse but this problem caused me to age a few years. Looks good but it breaks down under load.
  • Posted 2 Mar 2012 04:30
  • By Prentice
Anybody have a schematic for this truck?
  • Posted 2 Mar 2012 02:35
  • Modified 2 Mar 2012 02:35 by poster
  • By LTRM
Just got back to the jobsite this morning, frame grounds are solid, zero voltage drop on the B- side of things. tested at the frame near the ecu and the one near the left step all are good. the only place I get a voltage drop is on the engine itself during cranking but it is only.2 volt. I ran a B- jumper to the block just in case, no change.
  • Posted 1 Mar 2012 23:50
  • By LTRM
I usually add an extra ground cable. That works the best.
  • Posted 24 Feb 2012 11:40
  • By rogeriwt
Check the ground on the inside of the left frame. clean to bare metal...... id almost put money on it.
  • Posted 23 Feb 2012 01:38
  • By adam_k
  • joined 15 Dec'09 - 6 messages
There was an issue with the ground Cables/Straps not getting proper conductivity - Just a thought
  • Posted 23 Feb 2012 00:15
  • By Prentice
Taylor T650L
UN Forklift FGL35T
