Yale ERC080H/A839 EV200 power ?
How does voltage flow to rear panel/contactors?On this lift, Turn on switch.Relay solnoid under floorboard energizes.Steer motor starts running,[ deadman switch has been bypassed].Battey conntactor in rear,Does not close.Until shift lever is moved into for,or rev.Is this the way it should work? #2 Ive had battery out.Theirs a 12 volt relay,left side.Under battery,to the left of hyd.motor.what does this control? Thanks Kent
  • Posted 20 Feb 2012 00:49
  • By kent_w
  • joined 5 Jan'12 - 102 messages
If your EV200 panel is using a LX or ZX series EV100 card you can change when the SP contactor is energized by setting function 18. A setting of 128 or greater and SP is energized with For or Rev input, 128 or less SP is energized with a seat input.
  • Posted 21 Feb 2012 22:57
  • By Mpotter
  • joined 10 Oct'11 - 4 messages
Mpotter@fsip.biz
The 200 system is alittle strange, I dont work on the too often
  • Posted 21 Feb 2012 18:27
  • By 7777
Thanks,I believe this is [steer on demand] lift.They have two of these lifts.Power steer motor runs on both.Key on,seat down.Before for/rev selector has been engaged.One works fine.The other Im having trouble with no for/rev ,At times.for/rev contactor doesnt engage.Ive checked switches and Replaced control card.They own out good.I can allways get it working.By [Disconnecting current sensor @reconnecting it].Works everytime.I dont understand, How doing this.Gets it working.Im trying to get and Idea of whats happening.
  • Posted 21 Feb 2012 13:13
  • By kent_w
On that truck, the P/S motor should only be energized when, for or rev selector is engauged. When in neutral, and the key is "on", the hydraulics should be able to operate
  • Posted 21 Feb 2012 06:58
  • By 7777
Deborah Baker Deborah Baker
Crown WP302020
UN Forklift FD25T-C2JM1
Muncie, IN, United States
