koatsu engine swap
Help please I have just bought a komatsu forklift it has a nissan worn H20 engine & I would like to know if anyone can tell me what diesel engine would bolt straight on
Hope someone can help Denno
  • Posted 13 Feb 2012 17:55
  • By denno
  • joined 13 Feb'12 - 3 messages
sorry, just take a look!^_^
  • Posted 14 Mar 2012 18:09
  • By Aaron_68
  • joined 14 Mar'12 - 2 messages
  • fujian, China
YesSir, it would be far from a remove & replace. Get you a quality reman H20-----
It's a Komatsu, it will be worth it! I am assuming it is anywho!
  • Posted 14 Mar 2012 07:46
  • Modified 14 Mar 2012 07:46 by poster
  • By TheBirdman
  • joined 20 May'11 - 47 messages
  • Oklahoma, United States
Thanks roadtech sounds like I should scrap the idea
  • Posted 16 Feb 2012 18:12
  • By denno
Motor mounts will have to removed and rewelded, different cooling system,different exhaust system ,data tag will need to be updated (Good luck explaining that one to komatsu) plumb the fuel system, the transmission won't last very long even if you are able to adapt the flywheel ,different wiring harness and key switch, different starter means different bellhousing mount. By the time you're done you will about 3 times the price of a new truck, but hey I do wish you luck with that.
  • Posted 16 Feb 2012 13:33
  • Modified 16 Feb 2012 13:34 by poster
  • By roadtech
Thanks Michael I'll see what I can find out about the SD series
  • Posted 14 Feb 2012 13:25
  • By denno
The only one I know might come close is the nissan sd25. Don't really know about the flywheel housing to transmission bolt pattern. The nisssan parts manual only shows a difference in the trans case between the 5,000 lb and 6,000 lb trucks. Still it's just a guess.
  • Posted 14 Feb 2012 13:19
  • By meliftman
  • joined 31 Jan'12 - 209 messages
  • Alabama, United States
Liftman
Retired
Elberta, Al.
