Help with Hyster E60z-33
Hi friends, this time i have a problem with a Hyster E60z-33. Front and reverse is very slow and there isnt a code error in the display. Motor is OK.
Thanks for the help!!
  • Posted 1 Feb 2012 15:46
  • By oswaldomartin
  • joined 14 Oct'11 - 8 messages
  • Puebla, Mexico
Thanks friend, you were right, was the encoder :), but now i have another problem with the same machine the inclination of the mast is very slow, any ideas? Greetings!
  • Posted 2 Mar 2012 14:35
  • By oswaldomartin
  • Puebla, Mexico
usually the power of the encoder are 5/12 volt wire in red and black
to test the encoder you will have to have an encoder tester is a device with 4fios feeding the encoder with a battery and receives the signal from the encoder 2 leds
  • Posted 5 Feb 2012 11:35
  • By hysterbrazil
  • joined 10 Oct'11 - 101 messages
  • rio de janeiro, Brazil
Sure, the serial number is G108V02478B and there is not a alarm in the display. Someone know which is the value range for the proper functioning of the encoder bearing output? i think the problem is there and i want to chek, thanks!!
  • Posted 5 Feb 2012 10:47
  • By oswaldomartin
  • Puebla, Mexico
Please post the series of the machine and also has an alarm would be easier to post
  • Posted 5 Feb 2012 10:20
  • By hysterbrazil
you don't give a serial number so we are kind of guessing, but
it may also be related to the park brake or wheel brake switch. not all of them cut traction power completely, some just cut the torque way down on the traction circuit.
  • Posted 5 Feb 2012 04:06
thanks, i have reviewed the Sensor and is ok, i'm cheking the bearing, may be there's the problem
  • Posted 5 Feb 2012 03:29
  • By oswaldomartin
  • Puebla, Mexico
Since the problem occurs in both directions, I would start with the accelerator sensor.
  • Posted 2 Feb 2012 03:11
  • By meliftman
  • joined 31 Jan'12 - 209 messages
  • Alabama, United States
Liftman
Retired
Elberta, Al.
Deborah Baker Deborah Baker
SMV (Konecranes) 4632CC5
Terberg YT222
