Toyota brake issues in corrosive environment.
Hey guys I just recently got into LP trucks, and have the issue of two Toyota trucks not braking well. These two truck have about 5000 hrs. each. Every other day I have to go to this customer and blow out the dust in the drums and perform an Italian brake job (ridding the brakes till they get warm.) These trucks are in a very corrosive environment. Muddy metallic slush. The drums rust up and is a pain my A**. Any thoughts? these trucks are only in there for about 8 more months and then they are getting new trucks with a wet disk brake.
  • Posted 31 Jan 2012 10:48
  • By rlange
  • joined 19 Jan'12 - 1 message
  • Wisconsin, United States
the best thing you can do is trade the Toyota's out and put in the Doosan lifts with the OCD (oil cooled disc brakes) then you will not have any brake issues.
i have had some applications that were very rough and had the same brake issues you are talking about and i had to go to the Doosan OCD to solve the issues.
yes there are pro & cons to any lift truck but in your case the OCD brakes will far out weigh any of the Doosan cons.
  • Posted 10 Feb 2012 00:49
  • By bruce_c
  • joined 28 Jul'10 - 52 messages
  • Missouri, United States
This is one of the issues us BT / Toyota engineer's bring up from time to time, customers, salesmen & engineers all keep asking Toyota to drop the autobox / drum brake set up & go hydrostatic, will Toyota listen - NO they wont.
I know several customers have refused to purchase Toyota counterbalances because there not hydrostatic drive.
If I was buying a counterbalance truck with my own money, it would have to be a Linde.
  • Posted 31 Jan 2012 19:33
  • By Forkingabout
  • england, United Kingdom
Thought:
Very specific problem... If having blown in a dust really helps it is possible to try to organize tap of a dust from a working surface of brake shoes. To make a type notch \\\\\\on a working surface of a shoes depth no more 1,5мм. A residual thickness of an overlay not less than 2/3. Absolutely a problem won't solve :-( but it will be possible less often.
Won't be worse.
  • Posted 31 Jan 2012 13:02
  • By Last
  • joined 25 Jan'12 - 17 messages
  • Siberian, Russian Federation
UN Forklift FB25N1QZ1
Terberg YT220
Muncie, IN, United States
