code 53
ive heard that the code 53 is caused by a transformer in the drive board?? can anyone help?
  • Posted 14 Feb 2007 01:49
  • By scott_m
  • joined 14 Feb'07 - 1 message
code 53 is the 1 rec fails to turn off during the plug cycle. check your 2 and 5 rec, current sensor, and the 3 and 4 rec especially the 4 rec. if its made in india the is a problem with them replace both the 3 and 4 rec then. if you cand get it there is a PIB on these recs check with your local Crown dealer if they will give it to you
  • Posted 17 Feb 2008 14:25
  • By whoknows
  • joined 8 Feb'08 - 10 messages
Usually the Z-plug connector terminals are not making a good connection to the current sensor. A good cleaning,and lubing the connection terminals with Nygel works well.
  • Posted 17 Jun 2007 23:04
  • By Truck_Tech
  • United States
Mosfet broke down
But is this ev-T6 Box
Off send me de right info than I will send you the good info
Kindly regards
John
Netherlands
  • Posted 2 May 2007 03:35
  • By genjohn
  • joined 4 Feb'07 - 59 messages
  • NB, Netherlands
Sue Tomic Sue Tomic
Ice 24INCH-AUTO-SCRUBBER
USD6,396
Hoist Liftruck P360-48
