toyota E1 PUMP CURRENT SENSOR ABNORMALITY
Have anyone repaired this code e1 before.I ve switched sensor out.checked wiring.no luck with it.7fbhcu25 toyota,thanks kent
  • Posted 6 Jan 2012 08:03
  • By kent_w
  • joined 5 Jan'12 - 102 messages
First what are the input/output 3-8 readings. Without this info you are just gonna replace alot of good parts. I have seen this code caused by a bad sensor, bad cpu board, bad wires or cables, motor problems, and even had one occasion that it was due to a bad battery. If you give these readings I'll be glad to help
  • Posted 6 Jan 2012 11:13
  • By certifiedtech
  • joined 5 Aug'10 - 39 messages
Deborah Baker Deborah Baker
Muncie, IN, United States
