Toyota
Does anyone have any info. on the fuel system on a 7FGU25 serial 79508? It idles rough and cuts out when you give it the gas and then comes out of it if you hold the gas pedal all the way down. Smells rich at idle. unable to adjust the carb. enough to get a good idle. Is there a map sensor on this engine, looks like maybe one mounted by the carb.? Thanks. Keep those trucks a rollin. s.tjones at yahoo dot com
  • Posted 9 Dec 2011 00:15
  • By stephen_j
  • joined 4 Nov'11 - 34 messages
  • Indiana, United States
Have an email address to post in your profile or signature?
  • Posted 10 Dec 2011 07:55
  • By kevin_t
Did you drain the regulator? The Asian regulators have a drain on the right hand side that is a 12mm plug.
  • Posted 10 Dec 2011 07:52
  • By rogeriwt
yes you can have a regulator defect or it have a vaporizer you can check it is oke ,
possible the engine have to much LPG for working so you set the vaporizer settings right.
  • Posted 10 Dec 2011 04:57
  • By gc_d
  • Zuid-Holland, Netherlands
Regards gc_d
LP, did tune up, think it's a fuel issue.
  • Posted 10 Dec 2011 03:47
  • By stephen_j
is it a gasoline truck or an LPG truck?
  • Posted 10 Dec 2011 00:14
  • By gc_d
Regards gc_d
Probably need to adjust regulator. You will need a handheld to properly adjust levels.
  • Posted 9 Dec 2011 13:12
  • By rogeriwt
Muncie, IN, United States
UN Forklift FGL18T
UN Forklift FB25N1LZ1
