Caterpillar EP20K fault codes
I have a Caterpillar EP20K which is coming up with two fault codes, 13 & 18 - anyone any idea what these relate to/possible cause?
  • Posted 9 Nov 2011 02:36
  • By forklift101
  • joined 9 Nov'11 - 6 messages
  • Tyne & Wear, United Kingdom
gfletcheratsev.co.uk
  • Posted 9 Nov 2011 19:34
  • By forklift101
for this model 13 is related to the Drive IGBT and 18 is pointing a drive motor field fault. There is a lot to check to isolate the fault. If you post an email address i will send you some info.
Us at instead of @ when you post the email.
  • Posted 9 Nov 2011 07:36
  • By AndyPandy
Hi mate
the closest info i have is for a cat ep18k, info i have related to this states
13 - right drive motor faulty transistor drive
18 - right drive motor faulty field drive.
If this is the dc twin drive seperately excited motor controller truck and your transistors and motors read ok, it will most likely be a problem in the H bridge card(driver board for the traction field circuit).
  • Posted 9 Nov 2011 06:42
  • By elektrodrive
enquiries@elektrodrive.co.uk
ETB8B-00146 - 2004, 80v
  • Posted 9 Nov 2011 02:57
  • By forklift101
serial number?
  • Posted 9 Nov 2011 02:54
