Intermitent Idle Speed
The forklift runs not bad but the idle speed will not stay the same. While sitting there idling it will change from 600-1200 rpm on its own. It has 5500 showing on the hour meter, is running on propane fuel & at high rpm run decent but still not correct.
  • Posted 31 Oct 2011 06:53
  • By Ogie
  • joined 27 Oct'10 - 9 messages
sorry, assumed you had done that already, heat and lp quality here make us check the lp system first.
  • Posted 9 Nov 2011 13:34
  • By rick_c
  • joined 30 Jul'09 - 204 messages
We have resolved the idle issue by adjusting the idle mixture at the propane regulator. You can do this by knocking out the cap covering the mixture screw on top the regulator & turning till the surging stops. Why Toyota puts a cap on the regulator to cover up the screw up is beyond me. We have had issue's with the Aisan regulators used in the 7 & 8 series Toyota's but never new to knock out this cap or that it was even possible. Only after looking into our problem, but in other model Toyota's on Forklift Action having the same issue did my Technician try this & it worked. Thanks to all involved & using Forklift Action, Paul.
  • Posted 9 Nov 2011 00:25
  • By Ogie
Ogie's LIft Truck Ltd.
Thanks All Our Customers & Suppliers.
My Service Technician cleaned the throttle body with no change to the idling issue.
  • Posted 3 Nov 2011 23:26
  • By Ogie
clean the throttle body
  • Posted 31 Oct 2011 11:56
  • By rick_c
technology: (no user serviceable parts inside)
Sue Tomic Sue Tomic
Sue Tomic Sue Tomic
