Hi all,
I'm new in the forum and I hope you can help me to deal with my problem.
After changing the driving motor of this truck I got two error codes. Code 5 and code 196. Motor is dead...
Thank you guys in advance!
PS: Truck Type: Still R20 - 16, 2002
Hi all , can someone send me service manual for still R70 -25 , stuck on this forklift for a long time there is no Still dealer in my country no forward or backward , error 195 , and it does not have brushes
achigogava @ gmail.com
Hello , I have same R70 - 25 , with codes 195 and 197 it pops randomly , as i read your comments guys 195 is brushes problem but , current model have brushless 3 phase driving motor :S when forklift starts wheels trying to go forward/backward like crazy , can an encoder make this problem ? and also if posible if any1 know menu passwords , thank you. (tried 2999 didtn work)
hello I have a R70-30 still manufactured in 2001. it indicates error code 2, 57, 58, 195. if I'm working with it for more than half an hour the error 195 is displayed and the forklift drive is switched off and does not go no forward or reverse until it cools down. I think that something is overheated then the error 195 is displayed, what is the problem?
Hello!,
I have a R20-16P still, serial number 512009007488, manufactured in 2000. This indicates error code 69, error code 195, brushes.
What should I change?
Can you explain how errors are cleared at level 2 and what tools do I need for this?
Can anyone send me the manual to my email: jeremias028hotmailcom, please?
A lot of positive energy for all.
Hello!,
I have a R20-16P still manufactured in 2000. This indicates error code 69, error code 195, brushes.
Hello!,
Can anyone send me the manual to my email: [email address removed], please?
A lot of positive energy for all ! ! !
Hy
Can help me, please, with a service manual for Still R 20-16 or wiring schema, SN 512046002327 / 2004.
Thanks
you can read data out the truck in the display console withe the touchpads ,in the level 2 you can reset the errorcode list.
send me a mail
Hi, thanks for that information.
I'm sorry, but can you explain what level 2 means?
Hi , you can delete the errorlist in the level 2. The 195 code are drivemotor and 196 pumpmotor brushes.
Hi,
many thanks for your help!
Engine is running again, but error code 195 and 196 are still displayed.
To which brushes do these codes refer to (steering motor, traction motor)?
How can we delete the error codes?
regards
hi ,
code 5 pedalswitch
code 196 brush fault.
Check switch en brushes and connectors
regards
