Hydraulic question
I have a Mitsubishi FGC20CN that had a rotating fork assembly installed, it was worn out and we don't need it anymore so I removed it from the machine. I removed the lever and disconnected the hydraulic hose from the firewall that supplied the rotating forks. My question is, can I just cap off both connections or do I need to make a small hose to attach the two together. Thanks.
  • Posted 14 Sep 2011 21:13
  • By picklemike
  • joined 14 Sep'11 - 4 messages
  • New Jersey, United States
I think they may be #6 JIS (Japanese Industrial Standard)
  • Posted 17 Sep 2011 23:26
  • By jeremy_s
  • joined 28 Mar'08 - 205 messages
most of the cat/mitsi 3rd valve functions is #6 jic
  • Posted 17 Sep 2011 12:32
  • By TIMBO
  • joined 7 Jun'11 - 19 messages
Thank you. Do you happen to know what size the cap is I need? I am assuming it is metric. Thanks again.
  • Posted 14 Sep 2011 23:19
  • By picklemike
You must cap them off. If you joined the two together and someone pulled the plunger on the valve you would either blow the hydraulic pump, control valve or both.
  • Posted 14 Sep 2011 21:18
  • By duodeluxe
  • United States
duodeluxe
Kai von Berg Kai von Berg
