Nichiyu FB15PN-45-300 regulates the speed of pulling correctly
I would appreciate if some expert can help me
The truck begins to run when the accelerator is pressed normally to the throttle halfway SCR1 is ON then turns off only when the accelerator is released. The by-pass contactor is not activated at any time
  • Posted 22 Aug 2011 23:40
  • By edgardo_a
  • joined 26 Feb'09 - 28 messages
  • canelones, Uruguay
Hello edgardo, if can send me an email (marc at tuvo dot be) than I will send you some information about this problem. It' from the 46 serie but I believe that accelerator and controller.
kind regards
Marc
  • Posted 24 Aug 2011 18:10
  • By marc_b
  • joined 1 Jul'05 - 345 messages
  • ANTWERP, Belgium
Hi Marc, thanks for your answer. The thyristor SCR1 is triggered long before the microswich bypass is activated. Nor when you turn on microswich bypass contactor M3 is activated, no signal on terminal B of the target Purple. The truck only works well at low speed, when we reached the halfway point of the accelerator SCR1 is ON, if a bit decelerate the engine continues at full speed, only stops if you release the gas pedal
Regards
Edgardo
  • Posted 23 Aug 2011 23:24
  • By edgardo_a
Hello Edquardo, I would first see inside the accelerator. Normally there are 2 microswitches in (1 for starting and the other for the bypass).
kind regards
marc
  • Posted 23 Aug 2011 03:16
  • By marc_b
  • ANTWERP, Belgium
Lift Technologies Inc.
Kai von Berg Kai von Berg
Terberg RT223
SMV (Konecranes) 4632CC5
