Clark HWD/30 walkie
I have run into a technical problem on a Clark HWD/30 that I'm hoping someone can help me with. When actuating the emergency reverse switch the motor turns to start switching direretions & stalls within a second or two & then I receive an "open motor winding" fault on the Curtis controller which is reset by disconnecting power. I have 24V from the switch up to the DC controller & I swapped the controller with a spare unit with the same results. Any ideas that I may be missing?
  • Posted 22 Jul 2011 03:23
  • By todd_r
  • joined 22 Jul'11 - 2 messages
I understand your situation a bit clear now.
Have you had anyone put a Curtis hand set on this unit to trouble shoot the "black box" or compare the parameter setting? I would suggest you call in the Clark dealer to do this.
  • Posted 25 Jul 2011 03:53
  • By johnr_j
"Have An Exceptional Day!"
Johnr, thanks for the reply, my only question is that we have several of this model walkie & they all auto change direction to fwd when the belly button is pushed & stay in the fwd movement until the button is released. The unit in question only "bumps" fwd for a second & then the PLC faults out & you must disconnect/re-energize to clear the fault. All our units have the same model DC controller, so the logic, I imagine, should be the same. For safety reasons, we cannot use this walkie until the problem is fixed, due to the issue of having someone pinned behind the walkie as it will barely move fwd when the belly button is pushed. Any thoughts??
  • Posted 22 Jul 2011 22:56
  • By todd_r
This unit has a return to neutral feature, meaning when the emergency reverse switch (aka belly button switch) is activated) the operator (or tech) needs to moved the handle to the vertical or neutral position then select a drive direction. Part of the safety feature is to disconnect any drive signal when the belly button switch has been activated for operator safety. Hope this helps.
  • Posted 22 Jul 2011 06:59
  • By johnr_j
