Product protectors for forks
Is there a sleeve of some kind that can be put on forks to prevent damage, such a scratches on stainless pipe?
These will be used on class 7 (10k-18k capacity) lifts
  • Posted 19 Jul 2011 00:50
  • Modified 19 Jul 2011 01:00 by poster
  • By joe_d
  • joined 25 May'10 - 253 messages
Ain't nothing I can't fix but a broken heart and the break of day!
Joe, Arrow Material Handling has been around for 40 years and we make a anti-skid fork cover. We made it for freezer application that uses plastic pallets - but it may work for your application. It's not on our website yet amhattachments.com, but call me at 800-821-7563 ext 350 and I can send you a pdf file telling you more about the product.
AN INNOVATIVE SOLUTION FOR PREVENTING
LOAD LOSS!
* GRIPS PLASTIC PALLETS
* HELPS STABILIZE LOAD
* USE IN AND OUT OF
FREEZER APPLICATIONS
* PREVENTS SLIPPAGE DUE
TO CONDENSATION
Thanks
Milesl
  • Posted 25 Aug 2011 23:48
  • By Milesl
  • joined 25 Aug'11 - 1 message
  • Kansas, United States
Goals allow you to control the direction of change in your favor.
Brian Tracy
Joe, We are the makers of ForkSoXX. We are in Alvin, TX. You can see the product illutrated at our web site: triple w dot fork-co dot dom. or, call me at 281-692-1667. I have samples you can examine and customers you can interview, such as North American Stainless. We are Fork-Co USA.
We make these in any length. Size, in this case, does not matter :)
  • Posted 4 Aug 2011 15:59
  • By BrianS
  • joined 7 Apr'05 - 26 messages
Well, the stainless problem isn't the end of my problem here. I was informed this past week that on top of the stainless pipe getting marred we are about to get in some kind of high alloy pipe that cannot touch ANY kind of metal including eachother. Each pipe, after it comes off the production lines, has plastic "doughnuts" installed around the outside of the pipe to prevent it from even touching other pcs. of pipe of it's like. Poly fork protectors don't come in the length I need (97") so we're looking at nylon Forksoxx. I'll let you know how it works out.
  • Posted 3 Aug 2011 22:00
  • By joe_d
Joe;
We at one time had almost the same kind of issue that we addressed by copper electroplating.
  • Posted 3 Aug 2011 11:43
  • By MEngr
  • Missouri, United States
Good morning Joe, long time no hear. Is it hot enough for you down there? He we looked at the Jayline product protectors, hard rubber covers for the face of the forks, they look like they would work. They are currently used in the beverage industry to protect cans and bottles. They are made in the U.K.
  • Posted 22 Jul 2011 18:34
  • By chublil
  • joined 28 Jul'09 - 187 messages
Fix it right!!!
You can also buy them from Caldwell Company. The model is FC.... Their # is 1-800-628-4263.
  • Posted 19 Jul 2011 07:31
  • By duodeluxe
  • United States
duodeluxe
Call Superior Tire and Rubber they make poly fork protectors.
1-800-289-1456
  • Posted 19 Jul 2011 06:29
  • By scot_s
  • joined 10 Jun'04 - 63 messages
  • Michigan, United States
In the UK they have "slippers", its like a fork extension with plastic coating.
  • Posted 19 Jul 2011 05:23
  • By sean3
  • joined 14 May'11 - 46 messages
  • lancashire, United Kingdom
