Hard Starting/Extended Crank Time
Anyone have any ideas on how to cure a Doosan G25 P-3 S/N ML-01213. that has extended crank time and gets even longer when the engine warms up? The books say this delay is normal but it sure makes for unhappy customers.
Also, does anyone know where I can buy a service manual, disk, and dongle to work on this unit?
Thanks!
  • Posted 22 Jun 2011 09:00
  • By Gump
  • joined 10 Jun'11 - 30 messages
  • Iowa, United States
Showing items 1 - 20 of 22 results.
Thanks for all the input everyone! A lot of valuable information is much appreciated.
  • Posted 8 Sep 2011 23:15
  • By Gump
Find your Doosan dealer and have them update the ECM to V12. Cuts down crank time significantly. Fuel system supplier fixed the problem.
  • Posted 2 Sep 2011 22:21
  • By Miles
  • joined 6 Aug'10 - 4 messages
Gump
It seems this thread has intermingled 2 issues. Your 2.4L issue is different from the issue with the 4.3L
If you want to call me I can help you with this. 970-481-8351. More than happy to help.
ForkliftFan
  • Posted 19 Aug 2011 10:12
  • By Forklift_Fan
  • joined 28 Jan'11 - 9 messages
  • Colorado, United States
The unit is a L.P. Unit with a 2.4L engine. It starts somewhat quicker when warm but not like it should. Doosan says problem is normal....I told them they should try telling that to a customer who just spent $25K on one of their units! Engineers with Doosan state..."Normal crank time is 14 seconds" but this unit cranks for about 25 seconds when warm and a bit more, at times, when cold.
  • Posted 19 Aug 2011 07:21
  • By Gump
Gump;
What checks have been done at this time. I see G430E power package for this truck. Question is are we talking about a dual fuel Tier II, gasoline or LPG unit?
  • Posted 29 Jul 2011 05:44
  • By MEngr
  • Missouri, United States
Thanks for the info. Unfortunately this has turned into a back burner affair as I just got an additional 24 pcs. of equipment dropped in my lap at our other warehouse on top of the 113 I already had here. As long as it's runnin'!
  • Posted 29 Jul 2011 04:35
  • By joe_d
  • joined 25 May'10 - 253 messages
Ain't nothing I can't fix but a broken heart and the break of day!
Joe D, Gump,
My guys say check for poor grounding of the distributor at or near the intake manifold.
Also, if you can use Motoview to monitor RPM during crank to make sure you are getting a clean signal from the crank sensor. If you're not getting a clean RPM signal, it may be disabling spark until it sees a clean signal. I.E. software will not enable spark until it sees a RPM above 100 RPM.
Hope this helps, Forklift Fan
  • Posted 29 Jul 2011 03:11
  • By Forklift_Fan
I would go with the grounds. We have several Toyotas with the 4.3. When we get new trucks in we automatically clean all the grounds, and run an additional ground wire from the engine block to the battery. This has resolved the majority of our long start times.
  • Posted 20 Jul 2011 01:17
  • By kristopher_g
  • joined 20 Feb'07 - 6 messages
Ah the wonderful Lp powered 4.3... Check your compression with three steps. Dry, wet and than leak down. If this engine was not built with the prestolite (think that is the right name) valve seats than I suspect that you have burnt valves and valve seats. Had a number of failures of valve seats due to higher heat of LP gas ignition. The trucks would be hard start, act like they needed tune-ups, spit burp and backfire.
Good luck and let us know how you make out
  • Posted 12 Jul 2011 18:54
  • By mechnottech
  • joined 28 Feb'10 - 9 messages
this is a normal issue with machines fitted with ECM,
WIth this problem , starter are also getting damaged if compared to earlier Doosan machines ,
We can remove spark plugs and then try to see if spark is coming while craking.
spark plugs also to be changed as per manual.
  • Posted 1 Jul 2011 00:07
  • By amitrawat_r
  • joined 30 Jun'11 - 2 messages
  • Haryana, India
We had this problem with the vortecs in the Toyotas and to fix the problem we had to take all of the ground wires on the chassis off and grind the factory paint off down to bare metal. We found that the paint was insulating and we were not getting proper grounds just from the bolt threads themselves. You have to find all of the smaller grounds and not just the main negative. Hope this helps.
  • Posted 30 Jun 2011 21:44
  • By BusBoy
  • joined 20 Oct'09 - 14 messages
I can attach a spark checker and for the first 3-4 seconds there is no spark through the wires.
Joe,
I think this is the first think to figure out. "What's the system?" , as my mentor at Clark in the 80's would say. If you had a service manual and wiring schematic it would sure help.
If you are starting in 5 seconds then that means you are starting in 1-2 seconds after you get ignition fire.
Are you getting key switch voltage at the distributor immediately or does this take a few seconds also?
  • Posted 30 Jun 2011 21:07
  • By Forkliftt
  • Louisiana, United States
Steve
steve at forkliftt dot com
Does that truck have a diode in the ignition circuit. It would be in harness on right side of truck back next to radiator. It is a blocking diode between LP lockoff and ignition. Had one blown open once and caused hard starting. Picked up diode at Radio Shack, Truck started right away every time after that. Unrap harness and look for diode assy.
  • Posted 28 Jun 2011 08:43
  • By oldmanforklift
  • joined 12 Jun'05 - 25 messages
  • Arizona, United States
I would check into a service improvement from the factory on these things. Is the ignition looking for a set oil pressure reading before allowing spark? Just a guess, slow to build to working pressure, kinda like a safety prior to start? Remember the old Clarks had oil pressure switches that kinda did the same thing. Tokk a while to start, looking for oil in the pan.
  • Posted 24 Jun 2011 15:33
  • By chublil
  • joined 28 Jul'09 - 187 messages
Fix it right!!!
We've had the "long crank" issue since day one. A year or so again we started having back fire issues through the intake filter assy. We found that due to the backfires it had blown the mixer diaphram apart. That was changed and the regulator was changed. Still backfires. The factory insisted it was an ignition problem so the entire ignition system was changed (coil, wires, plugs, cap and rotor) and still backfiring. We could minimize the backfiring by adjusting the timing but the n we had this up and down RPM whil sitting. Then we pulled the mixer off and cleaned the throttle body. Same problem continued with idle, backfiring and long cranks. So i pulled the intake and gave it a good flushing. Now the idle issues and backfiring are gone but the "long cranks" are still there so even after putting on a new regulator the problem was still there.
  • Posted 24 Jun 2011 02:45
  • By joe_d
Well, the "good news" is thats not normal, which means it's fixable.
A hot restart should be in the 2 second range for the GM 4.3L.
Where in the US are you located?
My speculation is you have a regulator gummed up with "heavy ends". It's a tar like substance that makes the internals of the regulator act slowly.
If you're willing, I'd like to send you a regulator "repair" kit. Not sure if it's been released by Doosan US yet, but if youre game for it I'll send it to you. Basically you remove the regulator, take it apart, clean the tar out with carb cleaner and put it back together with the new gaskets in the kit.
  • Posted 24 Jun 2011 02:21
  • By Forklift_Fan
caseycasey84 at hotmail dot com
2550 hours on a GM V6 Vortec. It doesn't matter cold or hot by more than a second or so. More when cold but if you shut it off, wait and try and restart it still takes 4-5 seconds of "crank" time before starting. According to our LP guy, no and I only have this problem with this one lift (one of it's kind in the fleet).
  • Posted 24 Jun 2011 02:05
  • By joe_d
Joe D.
How many hours are on the truck?
Is that a Hyundai 2.0L or a GM 2.4L?
When the truck is "cold" (not started in the past 8 hrs) how long does it take to fire from the time you start cranking?
When the truck is warm, how long does it take to fire?
Are you in a area of the country that has high propylene content in your propane?
F.F.
  • Posted 24 Jun 2011 01:21
  • By Forklift_Fan
I understand the prinicipal behind it but on all my other LP lifts the engine actually starts in approx. 2 seconds of "crank" time but on this Vortec it takes more like 4-5 seconds of "crank" time. The entire ignition system is new and no vacuum leaks. I talked to the factory after the discussion here and was told that yes, the added delay in spark from the coil is designed in for the very reason you stated.
  • Posted 23 Jun 2011 21:19
  • By joe_d
hey joe, even modern cars with emission systems, do not get fire to the ignition coils until the ignition computer has seen at least 1 full revolution (#1 cylinder tdc 2 times on the crank shaft sensor). on units with GM HEI, this helps prevent a "roll back" where the ignition spark from the key moving between run and start causes the ignition of any combustible material in what ever cylinder was close to TDC on the compression stroke when the engine stopped last, and because that cylinder has not yet hit TDC, the engine rolls in the wrong direction, just as the the starter bendix hits. this is why some 4.3 GMs (among others) have a starter bracket that mounts to the back of the starter.
But.... that 2 revolutions happen so quick there is no way -that- adds to any cranking time that anyone should be able to notice, unless you were looking for spark from the coil wire.
have you taken vacuum measurements?
have you measured engine crank speed?
  • Posted 23 Jun 2011 09:41
GemOne
Sue Tomic Sue Tomic
GemOne
Sue Tomic Sue Tomic
