starting problem
This unit may start for 3 to 4 days straight @ 20 times/day & suddenly will not operate. As soon as we hook up a battery charger to it using the start mode on the charger, it will start. We've replaced about 4 starters & a battery thinking this was the problem because we can hear the starter solenoid clicking, but not turning the engine over when this happens.
  • Posted 24 Mar 2011 06:03
  • By buckshot
  • joined 8 Sep'10 - 15 messages
If it were my forklift, I would check the static voltage of the battery (12.69 volts is technically a full charge) and complete a load test on the battery first. You can then do voltage drop tests to determine if you are losing voltage through bad positive and negative cables. Also, check for voltage drop at the starter 'S' terminal. There can be a lot of voltage loss between the key switch, neutral safety switch and 'S' terminal. Low voltage to the starter solenoid can cause intermittent starting issues and decreased starter life. I hope that this helps!
  • Posted 13 May 2011 02:33
  • By Fork_Spec
  • joined 26 Jul'08 - 1 message
  • Colorado, United States
Lynn Brockman
Welch Equipment Co.
303-393-8181
Maxlion FB30EH
Crown RD572513TT6860R
Maxlion FB30EH
