Need Code Help E-27
We are working on a Mits, Model FGC25N serial AF82F00336
it is throwing an E-27 code. can anybody help with this. any info would be great. thanks
Doug
  • Posted 16 Feb 2011 09:33
  • By offroad72
  • joined 5 Jan'10 - 34 messages
  • Nevada, United States
check alternator belt tension also, make sure it isnt slipping at idle or whenm reving up. can cause some weird faults if belt is slipping
  • Posted 20 Feb 2011 11:16
  • By kevin_t
Clear the code,Change the spark plugs and check each coil pack, Fouled or worn plugs or a bad coil will cause this code also.
  • Posted 17 Feb 2011 06:52
  • By roadtech
crankshaft pos sensor signal not detected
  • Posted 16 Feb 2011 10:00
  • By ivan_j
  • joined 16 Feb'11 - 65 messages
ivan.forklift.man@gmail.com
Muncie, IN, United States
Kai von Berg Kai von Berg
Toyota 3FD100
Morooka MFD20
GemOne
