NISSAN W1F4A35U
I saw a new NISSAN W1F4A35U machine when i was looking around i was unable to see a hydraulic filter or transmission filter. like the engine oil filer those were not to be seen,
do they come with only a return strain filter that is mounted in side the transmission and hydraulic system ? what is the filter replacing period ?
i am not very familiar with Forklifts dont no if this is a common system that you place filter inside the transmission.
  • Posted 16 Feb 2011 07:17
  • By nuwan_s
  • joined 1 Dec'10 - 17 messages
  • Colombo, Sri Lanka
Thank you for the information, very helpful.
  • Posted 16 Feb 2011 16:38
  • By nuwan_s
Transmission, Hydraulic and Differential fluids are all changed every 2000 hours. We remove and clean the transmission strainer, replace the gasket then replace strainer every 3rd trans. service. Hydraulic filters and strainers get changed every fluid service.
  • Posted 16 Feb 2011 10:21
  • By roadtech
forklift transmissions can be considerably different than automotive transmissions, and some do only use a strainer or 2 in the lines. and it is not "rare" to find an in-tank return line filter in the hydraulic system
  • Posted 16 Feb 2011 08:50
Toyota 02-8FD25
Komatsu FD25T17
Yale Lift Truck Technologies
