Toyota 7FBMF16 Error E0
I have an electric AC truck serial is e12029.
It has 2 Danahar AC motion controllers fro traction and lift.
Truck drives ok when i pull the lift levers it throws up error code E0 and the truck judders as if the motor is trying to turn but cannot, however you can see the lift juddering and forks moving up very slowly.
Battery is ok, there are no earth leakages that i can pick up on the motor cables or the battery.
What i have found is that the connection to the motors the 3 motor cables are full of corrosion and rust, but cannot get to it as the back of the truck need to come off for me to get to the pump motor.
Now i have dropped a clamp meter on the motor cables and there is no current draw, even though the motor shakes the whole truck there is absolutely no current draw.
is this likely to be another encoder related issue??
  • Posted 11 Feb 2011 04:26
  • By elektrodrive
Showing items 1 - 20 of 35 results.
Hello are you have the solution of this probleme.
Thank you
  • Posted 12 Jul 2024 10:21
  • By Zouhair_Bekk
  • joined 25 Oct'19 - 4 messages
  • Morocco
could it be that the pump is seized seized ?
  • Posted 29 Sep 2019 20:46
  • By electrotech
  • joined 15 Apr'13 - 66 messages
  • Victoria, Australia
Reach for the sky
The basic instructions are:
Jack the truck up safely & secure the chassis at the front with suitable blocks.
Remove both front wheels.
To remove the mast - disconnect the hoses & wiring connector plugs, support the mast from the top, remove the lower mounting brackets around each side of the back of the drive unit, then remove both front tilt ram pins ( mark these before you remove them to add refitting )
Make sure all the drive unit & brake cables / pipes are disconnected.
HPT or PPT under the front of the drive unit assembly to support it & remove the chassis securing bolts each side.
Double check everything is disconnected then drag it out the front then replace the encoded bearing.
Refitting is reversal of removal.
This is a job best tackled by two people for safety / heavy item handling reasons.
NOTE: Remember the 7FBMF quirk ref the parking brake! It wont work with a front wheel clear of the floor - many get caught out by this fact & end up looking for a non existent fault.
Both wheels need to be on the floor for the parking brake to work.
  • Posted 29 Sep 2019 19:14
  • Modified 29 Sep 2019 19:20 by poster
  • By Forkingabout
  • england, United Kingdom
Forkingabout@aol.com
I have one of these encoder bearings to do in the workshop, now what is the best way to remove the motor? Not much space in there.
  • Posted 26 Sep 2019 19:26
  • By luke_m
  • joined 2 Feb'13 - 97 messages
  • Bedfordshire, United Kingdom
Hi am interested in a Toyota manual 5FB 4 wheel, you could tell me where to get it?
Thank you
Best Regards
  • Posted 17 Sep 2014 07:06
  • By jonatan_l
  • joined 17 Sep'14 - 1 message
  • BCN, Spain
larioss69@gmail.com
Hello!
Changing the motor solved the problem.
Regards
  • Posted 3 Sep 2014 18:42
  • By BLima
  • joined 7 Aug'14 - 9 messages
  • Funchal, Portugal
Hello!
I have changed the drives from one position to other, but still the same result. When I turn the steering wheel the motor turns well and does not pop-ups any error. Only when I try to move the joystick that the error appears.
We have requested a new motor. I will post the result!
  • Posted 29 Aug 2014 18:39
  • By BLima
  • Funchal, Portugal
Look after brush of steering when they are not goog they can blow up your SAS Print left side in the bach the transistor are defect.
thats your problem
regards
John.
  • Posted 29 Aug 2014 09:07
  • By johngen
  • NB, Netherlands
Hmmmm
This code on 7fbmf !!!!!
this code is on Fbm{f} with sids in the back {Transistor}
Problem sensor pompmotor wrong wiring position on motor
Twist both controllers and make new config on display
John.
  • Posted 29 Aug 2014 09:00
  • By johngen
  • NB, Netherlands
Yes. I have been looking at that motor. The ohm resistance is ok and between the terminals and the chassis it does not gives me any reading. I should used the megger but I did not have it with me.
  • Posted 14 Aug 2014 08:00
  • By BLima
  • Funchal, Portugal
That motor in the picture only does the power steering & releases the brake system.
Have you been working on the hydraulic pump motor in the back of the truck?
  • Posted 14 Aug 2014 07:42
  • By Forkingabout
Hello!
Thanks for the input. I think the steering motor is good since the fuse F3 is Ok and when I turn the steering wheel it starts spinning and then stops. So think it is ok. it does not give a error code when it turns/stops.
On the following link you will find a photo of the motor and sensor signals:
https://meocloud.pt/link/aec8cc1b-cd1f-4f34-bc56-6134ac08b291/Partilha/
When I press the joysticks and pump motor starts it poops up the error E0. I have measured the output signals of the encoder bearing and for me, they are odd. I think we should have two output signals and V+ and V-, but I have there three signals on the output!
The bearing as been changed, not by me, and the motor started working linear but slowly. Before that it was slugging when I press the joystick. I have changed the drives and still the same result.
Also the motor cables are warm after some time.
Could it be the problem is the motor itself?
Thanks and bear with me since I am new to forklift repair.
  • Posted 14 Aug 2014 05:28
  • By BLima
  • Funchal, Portugal
Hi, fault code E0 is normally short circuit in the power steering motor. So try to replace him and check again.
Greets Dave
  • Posted 13 Aug 2014 08:19
  • By toyotatechn
  • joined 13 Aug'14 - 3 messages
  • Antwerpen, Belgium
Hello!
This is my first post on this forum and I have came across with it because I have a forklift with the exact symptoms.
Can you indicate me what you have done to solve the problem?
We have already change the encoder bearing but still no result.
Can anyone indicate a good troubleshooting PDF/book for electric drives used in forklifts?
  • Posted 7 Aug 2014 06:19
  • By BLima
  • Funchal, Portugal
Thanks,
BLima
Veflex will be based on the older Reflex, there pretty good trucks, dont get much bother with them.
There is a mod for the turret head pot due to repeated error codes, ill fire it across later.
  • Posted 24 Sep 2011 21:47
  • By Forkingabout
look at your mail
Regards
John.
  • Posted 24 Sep 2011 19:16
  • By johngen
  • NB, Netherlands
lol no nothing that new yet :)
Just worked on a V flex Aisle truck recently but dont recall the year.
  • Posted 16 Sep 2011 23:56
  • By elektrodrive
enquiries@elektrodrive.co.uk
Most likely turn out to be something silly in the end once you find it.
Could be worse, you worked on one of the new Jan 09 onwards BT RRE Reflex yet?
  • Posted 16 Sep 2011 22:00
  • By Forkingabout
No worries mate
Its one in the workshop which we look at now and then hoping to crack it one day...
Would like to get to the bottom of it though lol
  • Posted 16 Sep 2011 21:57
  • By elektrodrive
Not had no luck with this E0 error code, none of my BT / Toyota colleagues have come across it yet.
  • Posted 16 Sep 2011 21:03
  • By Forkingabout
Kai von Berg Kai von Berg
