Intermittent Code 5f and 5g
Lift codes out for no apparant reason on startup. Some times you can turn on lift and use it several hours. Turn it back on and it will code.
  • Posted 19 Jan 2011 07:47
  • By BobRagsdale
  • joined 19 Jan'11 - 2 messages
I have this same equipment and it would code every so often. It now codes a 5H or 5G. I was told it's a communication code to check all connections or make sure battery is in good shape since i run electric equipment. I've tried everything and can't get code to clear. It will raise and lower but wont drive.
  • Posted 3 Oct 2012 04:42
  • By dennis_b
  • joined 3 Oct'12 - 1 message
  • Louisiana, United States
I am having this same problem, but only code 5G. Would appreciate any input. Thanks, Brad
  • Posted 7 Jun 2012 22:38
  • By BradC
  • joined 17 May'11 - 5 messages
  • Iowa, United States
SMV (Konecranes) 4632CC5
SMV (Konecranes) 12-1200B
Muncie, IN, United States
