ERROR CODE
THIS REACH TRUCK FLASHES UP CODE 07 ALWAYS WHEN DRIVE IS SELECTED.TRUCK WORKS AND OPERATES WELL THOUGH.THANKS IN ADVANCE
  • Posted 17 Dec 2010 03:54
  • By bruce_k
  • joined 10 Mar'08 - 15 messages
  • devon, United Kingdom
If the code flashes up as you go through the neutral position. This can be due to wear in all the linkages. The direction switches are closing to late or the traction pot is slightly out and inputing to the control card before the direction switch closes. I've seen customers put up with this for ages when it's not effecting operation
  • Posted 11 May 2011 22:59
  • By julesrobdog
  • joined 13 May'09 - 11 messages
yup its the travel pot happends on our Rd 3000 trucks...the pot need to be adjusted or replaced make sure the metal tab on the pot didnt slip out of its plastic holder..
  • Posted 5 May 2011 20:36
  • By irrk1
  • joined 5 May'11 - 24 messages
In the US, I see this problem on RR3000 reach trucks. I have to assume you have the European equivalent of the same truck with the EV100 motor controller.
  • Posted 17 Dec 2010 10:38
  • By Liftdoctor
  • joined 22 Jan'05 - 115 messages
  • Indiana, United States
Have seen this a lot. It is a pot or forward/reverse switch problem of a combination of the two. It rarely causes a problem with operation, although it can with a worn pot.
  • Posted 17 Dec 2010 10:36
  • By Liftdoctor
UN Forklift FD30-35T
Ice 28INCH-AUTO-SCRUBBER
USD8,350
F. Uchiyama
F. Uchiyama
