Clark C20SCL C152L throttle plate failure
Anyone have problems with the Bosch electric throttle/governor breaking the plastic gears and failing? Kind of an expensive part to be having to replace. Is a backfire through the intake system doing this? I did the coil mount mod that the service bulletin mentioned to prevent misfires.
  • Posted 25 Nov 2010 08:22
I was told by the local dealer it has to do with the version of software in the truck. Depending on the version in the truck, if you put a new throttle controllet on you will have the same failure down the road if you don't update. What were the codes?
  • Posted 30 Nov 2010 02:35
  • By joe_d
  • joined 25 May'10 - 253 messages
Ain't nothing I can't fix but a broken heart and the break of day!
Not a hot enviroment, but a dirty one.
  • Posted 26 Nov 2010 21:04
hey,
is this truck being operated in a hot environment?
  • Posted 26 Nov 2010 11:48
  • By steponmebbbboom
Enforcer FD50T-MMA
Terberg RT223
Enforcer FD50T-MMA
Terberg RT223
Enforcer FD50T-MMA
Terberg RT223
