Error Code
Toyota Model: 7FGU25 Serial: 83960. Engine light in the shape of an engine is on. Could someone please send the codes and process to retrieve codes on these newer toyotas.
Near the battery is a rectangular box with a two prong metal jumper, pulled jumper and turned keyon-gave an e.42 code. Not sure this is related to engine light. What is the SAS?
Email: alan(at)rrlift(dot)net
  • Posted 20 Nov 2010 00:59
  • By rrlift
  • joined 27 Feb'09 - 22 messages
  • Illinois, United States
Working so I can ride.
the light is the emission control system. there is a plug (6) holes next to the battery on about an 8 inch free pigtail. it has a cover on it. remove the cover, with the holes facing you...the wires away from you...and the lock tab on top jump the bottom row terms 1 and 2. (bottom row left two). turn key on count flashes. 1 flash (catch all) mixture or idle. 3 flashes vacuum sensor (usually wires broken). pull fuses for twc or disconnect battery to reset.
  • Posted 20 Nov 2010 08:52
  • By toyzilla
  • joined 29 Mar'10 - 175 messages
easier to ask forgiveness than to ask permission.
