hyster h200hs
can anyone explain how to remove the torque convertor from an h200hs hyster forklift have removed flex plate convertor nose cover, bolt,washer and bearing but will not pull from shaft i think its a power shift trans convertor made by twin disc inc.
  • Posted 10 Sep 2010 07:37
  • Modified 10 Sep 2010 07:38 by poster
  • By LEFTY
  • joined 5 Feb'10 - 3 messages
lefty
makes attention to remove the dishes in the middle of the drum torque, because the springs are a lot of pressure.
Ouvir
Ler foneticamente
  • Posted 26 Sep 2010 02:36
  • By AMartins
  • joined 8 May'10 - 107 messages
  • vila nova de gaia, Portugal
to anyone working on a power shift trans the front housing needs to be removed then the planetary gear seperate the convertor remove snap ring then shaft can be pulled what a pain!
  • Posted 25 Sep 2010 07:59
  • By LEFTY
