Nomad 50 check engine light help
Is there a diagnostic connector somewhere or how do I get codes out of the system?
Sorry. Nissan Nomad 50 , 4 cyl. LPG
APJ02A25EV
  • Posted 11 Aug 2010 07:30
  • Modified 11 Aug 2010 07:31 by poster
  • By 707Mental1
  • joined 11 Aug'10 - 3 messages
Sometimes these trucks will throw an oxygen sensor code if the fuel mixture cannot be regulated. Replacing the oxygen sensor in these cases will not clear the code. You need to check the mixer (carb) for excessive wear, check the idle mixture screw to ensure it is at the correct mixture (need an emissions tester to dial it in), and if the fuel control solenoid switch (a vacuum solenoid that connects engine vacuum to the ambient pressure vent on the vaporiser) is malfunctioning or has a leaking vac. hose, it will also throw this code. Call a technician who has the proper testing equipment and knowledge to do this.
  • Posted 5 Nov 2010 12:07
  • By steponmebbbboom
Were are right at the tail end of harvest. I should be able to check it out next week. I'll let you know and thanks for the input.
  • Posted 5 Nov 2010 03:04
  • By 707Mental1
Did you get that one fixed? Based on the model number, this has the Nikki CARB feedback carburetor system correct? These will turn the MIL on for simple stuff like an open/shorted coolant temp sensor, dead oxygen sensor, base fuel mixture out of whack, etc. There are very few components in the system so it is easy and quick to check. Adjusting the base fuel mixture can be a little tricky but no big deal. I have also seen a lot of dirt and moisture built up in connectors causing various problems on these.
  • Posted 30 Oct 2010 08:04
  • By WMC1
  • joined 29 Oct'09 - 7 messages
Thanks for the info. I'll check those things out.
  • Posted 14 Aug 2010 00:12
  • By 707Mental1
No hook ups on a JO2,These are the Pre-computer day trucks.
Check and fill the radiator resevoir bottle, if light stays on disconnect wires to confirm light goes out, most of the time the sensor float in the bottom of the bottle sticks, you can stick a low air pressure blow gun (20-30 psi) into the bottle and give it a couple of quick shots of air and that frees up the float. If not replace the entire bottle assy.
Also check LP tank bracket release micro-switch on top left side of counter weight.
  • Posted 13 Aug 2010 13:08
  • Modified 13 Aug 2010 13:09 by poster
  • By roadtech
