Problem of Jungheinrich ETV214-2008
Hi all Jungheinrich Experts,
My Jungheinrich truck model ETV214-2008 has problem as: after turning ON the Key SW, the display 3U7 only show the working hour meter without any else information - the main contactor K1 doesn't close. I have checked all the fuses are OK; have tried to make the bypass for the power contactor 1K7 but the main K1 couldn't be ON; change the new full charged battery but the problem is still the same.
I have tried to replace the display Julia 3U7 and MFC travel and brake 1U23 by the new ones taken from the good truck but the problem is still the same.
Due to the display does not show any error messages and any else support information so it is very hard for me to find the way how to check.
I'd be gratefull to you very much if you could please give me some advise how to solve this problem.
Thanks in advance & Regards
  • Posted 4 Jul 2010 21:50
  • Modified 5 Jul 2010 14:08 by poster
  • By Nuna
  • joined 12 Mar'09 - 189 messages
  • BK, Thailand
Thanks & Regards
Nuna
Email: nunatech2002@gmail.com
Hi Nuna
Does the truck use the Jungnheinrich 616k controller which is the dual unit which incorporates the Pump controller and traction in one? If so remove the black plastic cover from the top pf the card and if you look just underneath the card near the connector ends there should be 2 leds on either side, one for the pump circuit and one for the traction. You can get fault indication off this green lit leds indicate its ok unless a fault occurs you get a flashing red led very small but easily visible when lit.
I had a similar problem on an etv214 older version but used this controller. When i removed the cover i noticed the leds were not lighting up which indicated that there was a feed missing , feeds were ok and it was down to a card problem in the end.
If you leds are not lighting up check the key supply to the card input.
On the other hand if it uses the AS4814 controller it also has LED's on the top card from what i understand, might be worth looking to see if they give any fault indicators.
  • Posted 4 Jul 2010 22:47
  • Modified 4 Jul 2010 22:53 by poster
  • By elektrodrive
Linde Material Handling
