Is Toyota 7FBEU display interchangable w/ 7FBCU display??
  • Posted 9 Jun 2010 05:11
  • By J_Newton
  • joined 26 Sep'08 - 19 messages
Thanks for the translation Franco, I appreciate your help.
  • Posted 29 Jun 2010 02:38
  • By J_Newton
Hello Newton
I'm sorry for my English
you can exchange the two displays, you do not damage anything if they were not compatible is not lit. I have done these tests by replacing the display with the display of Japanese 7FB with the display of 7FBMF from this but come on, I can see what number it is.
The display connector cables are relevant for the cable data is not responding to the CPU that is off.
Regards Franco
  • Posted 29 Jun 2010 01:38
  • By franco_c
  • joined 28 Jun'09 - 25 messages
  • Bologna, Italy
e-mail: cf1990@libero.it
Thanks Franco, I appreciate the input, but I'm still left guessing as I don't understand Italian... (I'm guessing it's Italian)
non fossero compatibili Not compatible?
dati non risponde alla CPU Won't respond to CPU data??
Any translators out there??? Franco, could you answer in english?
Thanks,
John N.
  • Posted 28 Jun 2010 23:23
  • By J_Newton
Ciao Newton, puoi scambiare i 2 display, non si danneggia nulla, se non fossero compatibili non si accenderebbe. Io ho già fatto queste prove sostituendo i display del 7FB giapponese con il display del 7FBMF, da questo, se non si accende, riesco a capire di quale serie si tratta.
Nel connettore del display i cavi sono corrispondenti per le alimentazioni, il cavo dati non risponde alla CPU per cui rimane spento.
Saluti Franco
  • Posted 28 Jun 2010 19:51
  • By franco_c
  • Bologna, Italy
Really, no one knows if it would be a drop in replacement? I thought this would be a pretty simple question. At $2,000 each I'm hesitant to try without knowing for sure.....
  • Posted 10 Jun 2010 22:35
  • By J_Newton
Jeannette Walker Jeannette Walker
CEO, MHEDA
President, European Rental Association (ERA)
Chief marketing officer, JLT Mobile Computers
TCM FHD105Z
Terberg RT223
The use of "hello" as a telephone greeting is attributed to Thomas Edison. He is said to have suggested it as a simpler alternative to other greetings, such as "Do I get you?" or "Are you there?".
