Stuck on Forward even with key removed
Just today when I disconnected the charger, our forklift has stuck on forward. Pressing the Stop button does not stop it. Turning off the key does not stop it. The Raising and lowering of the steering mechanism is the only way to stop it. I have toggled the key and even removed it. It still moves forward. I had to disconnect the battery to stop it. Plug it back in and it starts forward again. Shouldn't the key off and removed be failsafe? Is there something simple I should check? I have a multitester.
Crown Walk Behind (30WTL)
  • Posted 28 May 2010 17:13
  • By EandKWood
  • joined 28 May'10 - 1 message
WithaK
visually check forward contactor to see if it is welded closed. removal of key is give away.
  • Posted 1 Jun 2010 09:10
  • By tonymfg
  • joined 16 Jan'09 - 43 messages
  • New Jersey, United States
Terberg RT403
Toyota 4FD240
