Clark CY50 wont go Forwards or Backwards
Hi, I have just taken over the refurbishment of the Family's Clark CY50 forklift. ( hasn't been going for about 8 years, but was driven to it's current position.
I have got the beast starting & running, all the hydralics appear to be functioning ok, but when I put it into either forward or reverse, it will not move.
My initial thoughts are
1. ??? Transmission fluid is low ???
... where is the dipstick / filler point & what type of TX fluid should I use.
2. safety switch ???
3. beats the **** oft of me At the moment.
all coments appreciated, thanks
  • Posted 15 May 2010 21:30
  • By geoff_j
  • joined 15 May'10 - 4 messages
  • Northern Territory, Australia
Hey, Geoff.
Hows that CY-50 going, has it still got original grey motor & what year is it.
I have a CYF-50 (Friction clutch) converted to CY-50 (Torque converter) , I got the original build card from clark USA, it was built in 1964 with Holden greymotor. It now has a 186 red motor. Mine also has short mast, I can only just load onto top of container.
I had lots of problem with slip when hot. Ended up being the floor pan modification ! The brake pedal was not returning enough & when every thing was hot the master cylinder pushrod had negative clearance & was activating the inching valve.
So bashed th floorpan & adjusted the pushrod & now all is sweet.
cheerz
  • Posted 24 Nov 2010 10:54
  • By tonigau
  • joined 26 Aug'08 - 7 messages
  • Queensland, Australia
Geoff, the canister in question could be your motor oil filter(napa 1010). if it does not have a spin own filter. Follow the lines off the cannister and see if they go toward the engine block. Also, if they lead back to the hyd. tank then you know thats it. Mark
  • Posted 1 Jun 2010 03:36
  • By mark_l
  • joined 12 Mar'10 - 19 messages
Great... all is proceeding..... The beast is working again,...with a new leash of life, Forward & Reverse, Mast goes up & down...
Well until the Fuel Pump failed,:( fixed that :) & went for a quick spin, Then radiator boiled... :(
Have a new thermostat ready for install this weekend. :)
Now I have been told elsewhere that hydraulic fluid has a tendency to absorb water, & I was advised to change the Hydraulic filter, else the hydraulic pump may fail sooner than later...
I have had a bit of a snoop around & I have found a large blue metal canister , aprox 8" round & 6 - 8" high with a nut on top, I havn't investigated inside this yet, but I assume this is possibly the Hydraulic filter ??? yes/no ??
Any guesses of the part number for the filter ??
Thanks again for all the help here
  • Posted 31 May 2010 22:07
  • By geoff_j
Geoff, usually theres a large black or could be chrome cap on the hydraulic tank either on the left or right side of the frame of the truck. Sometimes theres a dipstick under the cap. if theres not a dip stick on cap there should be one ajacent to it. Make sure you do not put oil in the gas tank. Mark
  • Posted 21 May 2010 10:40
  • By mark_l
Mark,
thanks for the tip, but where is the fill point for the hydraulics ?
  • Posted 21 May 2010 10:11
  • By geoff_j
Geoff, could not tell you how much it holds. I would just fill it to line on dipstick and rock on. As far as the hydraulic oil, be sure to check with forks down and tilted all the way back otherwise you can easily over fill tank and wind up with a tremendous mess in your floor. Lift height depends upon upright size as there are different sizes in which will go on lift
  • Posted 21 May 2010 09:58
  • By mark_l
Thanks for the great feedback guys, your comments were very helpfull,
I checked the dipstick on the front dip & nothing showed, I've added 4 Litre's of TX oil & I now have movement. Just wondering how much oil the front diff holds.
Also.. how do I check the hydraulic fluid & what is the max fork height, as I have read comments that the CY50 lifts to 4Metres, but this one definately dosn't go that far.
It appears the chain is at full runout & the Ram is at or close to full extension ( unless there is another inner ram that is not extending due to low hydraulic oil.
  • Posted 21 May 2010 09:29
  • By geoff_j
also, check to see if theres a suction filter in the trans somewhere. Usually when a truck sits for a long period of time the suction filter will clog
  • Posted 20 May 2010 10:19
  • By mark_l
  • Posted 20 May 2010 10:16
  • By mark_l
I would say that it could be one of four problems:
1. Low transmission fluid level
2. Problem with the inching valve.
3. Bad transmission pump
4. Needs transmission rebuild.
The first two thing are simple to check. On the last two you would need to do a transmission pressure test to identify the problem.
You could also a broken axle shaft or differential issue but that is more unlikely.
  • Posted 19 May 2010 21:43
  • By duodeluxe
  • United States
duodeluxe
The dipstick is on the dfferential case up in the front of the truck. Tilt forward and look down between the mast and the dash panel. That's where you fill it too. There is no safety switch that shuts off the trans.
  • Posted 17 May 2010 20:41
Taylor T520S
SMV (Konecranes) 4632CC5
Taylor T520S
