Stalling unit.
I have a truck that, when traveling full bore tractor first, stalls (for lack of a better word) for a second then resumes. It does this more frequently as the battery goes down, but will do it with a fresh battery. I have been told that this has been happening since the unit was new (before my time here). Anyone else having this problem? Any ideas?
  • Posted 21 Jan 2010 08:53
  • By jeff_i
  • joined 2 Nov'08 - 15 messages
  • Iowa, United States
Jeff it depends on the control system,and what else is happening. Do you know the serial number? Does the unit throw a code when this happens?
I would be suspicious of the deadman pedal/switch and control handle.
Its possible the switch is cutting in/out or is damaged or the wiring to it is damaged. Same with the handle in most models.
Does it sound like the motor is disengaging when this happens? Maybe a
tripped gear?
  • Posted 21 Jan 2010 23:09
  • By JonG
  • joined 7 Nov'07 - 155 messages
  • United States
Oxford Ct, United States
Esie Cortez Esie Cortez
