Pump Motor Control
My pump motor control is failing. I have a technician who is trying to fix the problem, but unfortunately, I fear we are down to buying and replacing part after part in hopes of a successful repair... On this truck, the pump motor is controlled by it's own EV1. There is a metal box under the gas pedal that houses the EV1 and various rectifiers and other components. There is neg/pos supply and neg/pos out to the pump motor. The only other wires are one ~16ga which we believe is connected to the dash light to indicate an overheat in the pump motor.
Short of trying to diagnose the problem here (the tech is still doing his best), I am wondering if there is an option for an aftermarket or more recent component that I can use to perform this function. This would be some type of pump controller that receives the full 36 volts and then divies out the voltage to the pump motor as demanded (i.e. responds to motor load by increasing voltage). The one other input I forgot to mention is a switch that forces the control to max voltage for the boom lift operation. Rather that try to dignose this antiquated (and VERY expensive due to limited part supply) old controller, it'd be great to just replace it with something more modern and reliable.
Le me know if you have any ideas! As always, thanks for your contributions!
  • Posted 4 Dec 2009 10:03
  • By Suker4Deals
  • joined 11 Nov'09 - 2 messages
  • Washington, United States
I'll check them out, thanks!
  • Posted 4 Dec 2009 17:41
  • By Suker4Deals
I am slightly surprised to find you think this controller's components to be expensive. have you priced the parts from Flight Systems Industrial Products? their web site is fsip.biz (not.com)
and sure, there are a number of other controllers that can do the same job. (but I doubt they are less expensive).
If your tech is not all that sure of how to troubleshoot the controller down to the SCR level, Flight systems can do a complete controller repair and get it back to you within a week, but they may well have a unit on the shelf that you can order and have a core charge and credit for, and the cost really should be less than any alternative.
  • Posted 4 Dec 2009 11:15
Toyota 4FD240
SMV (Konecranes) 4632CC5
