No sideshift or tilt
I've a unit with a really slow s/s and no tilt. Pressure check shows 200lbs. with s/s activated and 0lbs. when activate tilt. Lift operates fine and has good pressure. All solenoids are operating fine and have power at appropriate times.Could this be internal leakage in the big solenoid block or tandem pump?
  • Posted 17 Nov 2009 07:44
  • By mudforce
  • joined 17 Nov'09 - 5 messages
  • Alberta, Canada
From Admin...some anonymous reader (who was not logged in) commented "Change tandem pump".
Perhaps that comment may help you...perhaps not.
Good luck,
Admin
  • Posted 30 Jul 2019 09:48
  • By Admin
  • joined 18 May'04 - 266 messages
  • Queensland, Australia
Esie Cortez Esie Cortez
Oxford Ct, United States
