nissan service info
can anyone help me with fuel/oil filter part numbers for a nissan fgj02 circa 1995 with a td 27 engine,also valve clearances,thanks
  • Posted 5 Nov 2009 07:55
  • By markg
  • joined 27 Oct'09 - 57 messages
  • n lincs, United Kingdom
thanks for your help guys,all the best.
  • Posted 6 Nov 2009 07:01
  • By markg
Nissan OEM #'s are:
Air- 16546-51H00 ( this is what is on most J models with a TD27)
Oil - 15208-43G00
Fuel - 16405-T9005
Fuel filter O-ring- 16407-W4900
(replace this O-ring when you change fuel filter,a lot of poorly trained or sloppy techs don't and loose this when they pull the old filter off,or don't know it's there and start having issues with starting.) It sits at the top of the tube on the fuel pump/bleeder.
Take the time and just remove the battery to gain access to the filter, it make the job go a whole lot smoother with it out of the way.
  • Posted 5 Nov 2009 14:58
  • By roadtech
nissan engine use a quite std filters for there engine
crossland numbers fuel 370 or 5013 oil 2029/694 or 2048
valve clearances 0.35mm [0.014 in]
  • Posted 5 Nov 2009 09:27
  • By greasespoon
  • joined 30 Jul'09 - 154 messages
  • somerset, United Kingdom
Spencer/Sheldon/Sioux Rapids, IA, United States
SMV (Konecranes) 20-1200B
UN Forklift FBRS15KQZ2
