no 3rd speed
I have an older series M walkie lift. The 3rd gear isn't working. In the past it was usually just a switch or wiring problem in the handle. This time the connector switch B doesn't seem to activate, it just seems to rattle back and forth and doesn't make contact. Any help appreciated.
  • Posted 16 Oct 2009 06:31
  • By jackw
  • joined 16 Oct'09 - 1 message
  • Illinois, United States
you can also check for debree in the contactor as the terminals on the contactor for the coil frequently drop out. I have even had occasion when a piece of plastic has logged between the tips. Third speed switch above the 3rd speed contactor also suffers from dry or broken solder on occasion. Rabbit switchs are also notorious for internal corrosion or failing contact.
But i think Tony may be right, low voltage is the most common cause.
  • Posted 14 Mar 2010 09:59
  • By ryan_c
  • joined 8 Mar'10 - 10 messages
  • Queensland, Australia
If the batts are o.k., check harness that runs under/by the drive tire. I have seen alot of them chaffed. 3rd speed, meaning no contactor movement? (high speed contactor-the one with the switch mounted to it?) check negative voltage.
  • Posted 21 Oct 2009 10:13
  • By tonymfg
  • joined 16 Jan'09 - 43 messages
  • New Jersey, United States
Sounds like the batteries need a charge or there is one or more bad batteries. I would check them with a volt meter while operating the lift to put them under a load.
  • Posted 16 Oct 2009 10:07
Deborah Baker Deborah Baker
Muncie, IN, United States
Crown RD572513TT6860R
Manitou MH25-4
