Contactor issue
I ahve an N01L15U that will run fine for about the 1st half hour in the morning. When it starts to warm up when ever you take your foot aff the accelerator and then press it back down all the contactors kick on and off about three times and the truck will take off. It looks like tips are fine and both d/m contactors and the line contactor do this. The green status like on the computer stays on the whole time. Any help will be greatly appreciated.
Thanks
Roger
  • Posted 14 Sep 2009 12:20
  • By rogeriwt
Thanks for all your help. I will try cleaning them up the next time I service the truck.
  • Posted 18 Sep 2009 11:37
  • By rogeriwt
try this remove contactors units and clean them up. there my be dust inside where the contacts sit
or a faulty coil or contactor unit
  • Posted 18 Sep 2009 08:56
  • By greasespoon
  • joined 30 Jul'09 - 154 messages
  • somerset, United Kingdom
Battery tested fine. I did not test the coils. Will one bad coil make all 3 act this way or are they all suspect?
Thanks for your help
Roger
  • Posted 16 Sep 2009 10:55
  • By rogeriwt
have you tested the batterys cells and the coils on the contactors this my cause the problem?
  • Posted 16 Sep 2009 08:32
  • By greasespoon
TCM FD115-3
Crown CG33P5
TCM FD115-3
Crown CG33P5
