Crown sp 3500
I'm working on a Crown SP 3500 ac drive truck. It intermittetly slows down to a crawl once or twice a week for maybe 10 seconds then goes back to normal speed. Platform is all the way lowered when this happens and moving the throttle handle doesn't effect speed. There are no height switches on this truck ,it has a height encoder. No codes are registered when the truck is moving slow. Any one have any ideas? Thanks.
  • Posted 6 Sep 2009 12:38
  • By amxjavman
  • joined 3 Sep'09 - 9 messages
  • Wisconsin, United States
The speed on the sp 3500 stock picker is set to 3.4 which is incredibly slow , the access code (2311) is invalid. Is there another code that could enable me to change the speed?
  • Posted 11 May 2016 22:50
  • By Manmaderae
  • joined 11 May'16 - 1 message
  • Maryland, United States
Maximum speed on the SP3500 AC Drive is 7.5MPH, you will go through alot of load wheels and drive tires at this speed...
  • Posted 28 May 2015 03:01
  • By Mercanyin
  • joined 6 Sep'14 - 23 messages
  • Arizona, United States
I work with a crown sp 3500, and I was curious as to how I can improve the speed of my truck, right now its going 7.5 mph I would like to know whats the maximum speed. thanks
  • Posted 31 May 2013 10:12
  • By charlesbarkley
  • joined 31 May'13 - 1 message
when goes into crawl does it give you any tones or beeps??
  • Posted 9 Jun 2011 23:53
  • By juan_s
  • joined 31 Dec'10 - 1 message
Found the problem. The pot would intermittently lose.5-1.0 v while going forward for a couple of seconds, then go back to normal volts. Swapped it out and truck runs great. Thanks for the help.
  • Posted 18 Sep 2009 19:18
  • By amxjavman
Go into the SERVICE menu level 2,enter the password(2311) and go to ANALIIZER menu. Select A2.3.3 and look at the Accelerator POT voltage reading while operating the travel at full throttle. Make sure the POT isn't turning to far past it's sweep.
  • Posted 7 Sep 2009 01:27
  • By Truck_Tech
  • United States
SMV (Konecranes) 12-1200B
SMV (Konecranes) SL37-1200A
