power
I lose power after about 10 min. of running. ldles fine.
  • Posted 2 Sep 2009 05:10
  • By garceneaux
  • joined 2 Sep'09 - 4 messages
  • Louisiana, United States
thanks, had code e-32. Found pin hole in radiator, about 2 or 3" from the top. Low on antifreeze. Thanks again. Have a good day..
  • Posted 2 Sep 2009 20:25
  • By garceneaux
It's called "Limp home mode". This system detects faults or problems and allows the operator to move truck to safe location or back to repair area. Are there any codes or dash lights flashing on or near the dash where the hour meter is?
What type of application is the truck used in? The truck will do this if the transmission sensor gets wet or fluid is burnt.
  • Posted 2 Sep 2009 10:08
  • By roadtech
