won't run
I am working on a 7 series LP truck. when the engine is cranking, it fires and runs until i release the key switch. I don't lose spark, the voltage to the fuel solenoid drops out.
  • Posted 30 Aug 2009 04:02
  • By FF81
  • joined 13 Aug'09 - 15 messages
Check the wires at the distributor connector. It uses a signal from the dist to turn the solenoid on. If the wires are ok post if the truck is an ECS engine or non ECS and I can give you a few more leads.
  • Posted 30 Aug 2009 12:00
  • By bret_h
  • joined 26 Jun'09 - 15 messages
Crown CG33P5
Airman ENCL045
Briefs United States
