ERROR 107 RRE2ACCS
Any help? Mahcine stopps every now and then. Must turn off and on again... Help!!!
ERROR 107
  • Posted 29 Aug 2009 01:14
  • Modified 29 Aug 2009 01:22 by poster
  • By mario_s
  • joined 2 Jul'09 - 23 messages
  • Porto, Portugal
107 Usually means you have a faulty k10 main contactor or faulty a5 card
first try taking the contactor apart and cleaning it as this is sometimes all it takes
to retify the problem. Also check seat switch wires as these sometimes get cut through where they go into the seat.
  • Posted 11 Oct 2009 02:33
  • Modified 21 Nov 2009 23:19 by poster
  • By powerlifter
  • joined 17 Mar'09 - 306 messages
  • united kingdom, United Kingdom
A good engineer is a helpful engineer
you must to check, first ,the fuse F62 behind the traction motor, check too the principal contactor and the wires to his coil.
When the contactor K10 is on, the A5 card must receive (+) at pin 808.
  • Posted 20 Sep 2009 21:26
  • By nacsand_n
  • joined 20 Sep'09 - 716 messages
  • Madrid, Spain
