hot cables
when using the lift the battery cables to disconnect gets very hot pos only need help thanks
  • Posted 23 Aug 2009 00:42
  • By squidman
  • joined 12 Mar'08 - 23 messages
  • Rhode Island, United States
oneshotmech@yahoo.com
Replace the connector on the truck and the battery. You can't go wrong there, even if it does not fix the problem. By replace, I mean the tips and housing. Don't just replace the housing. Resistance in the connection between the tips and the cable means HEAT.
  • Posted 12 Sep 2009 23:42
  • By Liftdoctor
  • joined 22 Jan'05 - 115 messages
  • Indiana, United States
have your battery company replace the cables, if ONLY 1 cable is getting hot. have your battery checked out for "voltage drop under load".
lower voltage = higher amperage = (same wattage to do the work) but more heat. since electric power is a circuit, the flow on both cables is equal, if only 1 is getting hot, then that one (most likely) has broken down inside the insulation.
also check the connector to the battery (all 3 halves, truck, battery and charger) charger half may have a weak spring or cracked case causing poor connection at the charger, causing poor connection on the truck and battery too.
  • Posted 23 Aug 2009 02:35
  • Modified 23 Aug 2009 02:38 by poster
UN Forklift FGL25T
Terberg YT223
VETTER Industrie GmbH
