CODE 2-2 AND HIDARULICS NOT WORKING PUMP MOTOR AND CABLES ARE HOT
HI I HAVE A CODE 2-2 AND MY PUMP MOTOR IS GETTING REALLY HOT AND SO ARE THE CABLES I REMOVED THE MOTOR AND SERVICED IT (BLOW IT OFF) CHECKED CABLES AND CONNECTORS. IF YOU NEED MORE INFO I WOULD BE HAPPY TO LET YOU KNOW THANX
  • Posted 18 Aug 2009 13:05
  • By marc_a
  • joined 19 Feb'09 - 31 messages
  • Baja California, Mexico
i went ahead and removed the hidraulic pump and the motor is still overheating it pulses and turns really slow i removed it and sent it to the electric motor shop. they will let me know by tomorrow. also the temperature here is about 115 F. this time of year. thanks for your info it really helps
Thank you guys
  • Posted 19 Aug 2009 05:50
  • By marc_a
you are right. didnt even notice the hot motor and cables. was stuck on 2-2 w/ no prefix. insomnia.
  • Posted 19 Aug 2009 03:36
  • By rick_c
  • joined 30 Jul'09 - 204 messages
technology: (no user serviceable parts inside)
I am Assuming it's a code E2-2 - Pump motor thermo sensor abnormality
You need to Check Thermo sensor - looks like it's heating up for some reason ( low fluid, plugged filter, very hot day)
  • Posted 18 Aug 2009 22:16
  • By Prentice
need to know what the model # is. 2-2 sounds like a pallet jack curtis code. if so,(7series) it is a simple sequence problem. check the brake switch and or handle switches. this usually happens when brake switch is on when key is activated or directional sw is on at key on.
good luck.
  • Posted 18 Aug 2009 13:33
  • By rick_c
Aichi RX07B
UN Forklift FB25N1QZ1
