julio_r
Texas, United States Hello, Everyone My name is Julio and we have 2 Linde's here in our plant, and we been running into problems the linde H50D is giving us some code "221" and "280" and just wondering if anybody can help me out here, once the code go off the linde wont lift anything and it runs in low speed like were forcing it, can someone please help me out I'm kind off new to linde's, I would be thankfull...
T 483 safety processorpomp control in forward direction notplausible in relation to accelerator potentiometer
T 248 speed sensing fault
D 156 traction heartbeat masage mising for over 400ms
T 221 production test not ok
L 280 safety relay Always off
Hello guys,
I have a linde truck model H30T,I have a fault D156.
Can somebody tell me how I can fix this fault?
Thanks in advance.
Hi Herald I appreciate your help, this morning as we started the Linde it looks like the codes were gone but as I start to drive it around the forge shop I notice two different codes "T483" "T248" and now and very confused it looks like were going to have to get a Linde guy over to hook up the computer but this days there so expensive per hour......Thanks for you help Herald
Hi julio
The fault code 221 should have a T (traction) or L(hydraulics)before the code if it has a T then you have a voltage problem inside the controller.This fault will cut drive to creep speed.
The second code 280 is a hydraulic code and again is a low volage fault inside the controller.This fault will disable the hydraulics.
It looks like you will need to replace the control module in the cover behind the seat.
cheers
herald.
